CNG Gremlins
Thread Statistics:     Users to Post: 1   |   Total Posts: 1   |   Total Views: 387
ccappaul
• Salt Lake , UT, USA
• Registered on 9/21/2011
• 7 posts
Posted:9/21/2011 21:07
Ok Folks, Its a long story. I\\'ll try and be concise.
98 Dedicated Cng, 162 K .
Problem: It will be running fine then - Barely chugs out a 500 rpm idle
Live Data read
02 sensors go flat lean and stay there,
Long and short fuel trim Max to compensate + 20
No response from the 02s
Frequency : Whenever it feels like it
Duration As long as it wants
Story: I can spray starting fluid into the air intake and it will idle up just fine
as long as there is spray.
Not getting Fuel. OK
Fuel Pressure stays at 75 lbs (Remember its natural gas thats normal)
Injector trims max out
Injectors sound and feel like they are opening
Runs Fine before / Runs fine after eventually , If it wants to
Injectors have been removed and cleaned. ECM has been replaced. But it has an NGV Module behind the grille that ? (Runs the injectors I have gathered ?)
CNG Gremlins
