SCamFam5
Atlanta, GA, USA |
Registered on 12/6/2011 |
1 post |
Posted:12/6/2011 09:16 |
does anyone know where the pcv valve is located on a 1999 crown vic. 4.6? |
Lafayette, LA, USA |
Registered on 1/5/2009 |
525 posts |
Posted:12/6/2011 10:18 |
All pcv valves are located on top of the valve cover. Some have one(1) on the passenger side, while others have it on the driver's side. Some even have a pcv valve on each valve cover. Look for a 1/2inch (13 mm) vacuum line going to the top of the valve cover. Connected in this line is the pcv valve. Some pcv valves are straight and others have a 90 degree offset to them. Most of the auto parts houses should be able to show you were it is and change it for you.
