No overdrive
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 913
litemup
• Jefferson City, MO, USA
• Registered on 12/17/2011
Posted:12/17/2011 08:02
Any easy fix I can look for to get my 89 Lincoln Town Car to go in OD Shifts fine to 3rd and will run 70 easy. Only 82,000 miles.
wizzard1222
• Ballwin, MO, USA
• Registered on 1/27/2011
• 139 posts
Posted:12/17/2011 08:24
...simple answer...NO
However, you could try a fluid-N-flush...maybe two of them w/about 100 to 500 miles run between them. You could also add some trans specialized fluids like Resolve...etc.
I did this w/1 fluid-N-flush last spring. My OD would slip around 43 mph and I would have to do the hand shift back to little D. The gas mileage is not great normally....even less w/3rd gear OD...!!!
Anyway, after about 1000 to 1500 miles...the 'regular OD' started to work/run properly....
My odometer doesn't work because of the original Ford plastic gears on these components....!!!
It has failed again a few times but it is again working properly for the past 300 miles (est.)...
It's worth a shot.....
No overdrive
