oil in the air filter
Thread Statistics:     Users to Post: 4   |   Total Posts: 7   |   Total Views: 1246
topfisherman
• Unknown, WI, USA
• Registered on 4/24/2003
• 13 posts
2 Vehicles
Posted:5/25/2003 13:09
I have a 1992 Bronco with a EFI 302. A few months ago I noticed the engine started blowing oil into the air box and the truck lost a lot of power. i figured out there was a lot of backpressure and had the cats checked out, they were fine. Then I found out the muffler was clogged and I replaced with a glasspack muffler. Almost all of the truck's power came back, but it is still blowing oil into the air box (although not nearly as much oil as before). I checked the compression and the numbers were almost as high as when it was new. I also replaced the pcv valve twice thinking that was the problem, but it wasn't.
Please help, I can't find any info on why the motor is doing this.
John Barrett
• West Palm Beach, FL, USA
• Registered on 1/31/2003
• 106 posts
Posted:6/10/2003 23:30
Did you try pulling the valve covers off and replacing the valve seals.
you maybe getting blow by and though the pvc valve back up into the intake.
Also how many miles on this motor, may need to put brass valve guides in, they wear on the ford heads.
Hope this helps
topfisherman
• Unknown, WI, USA
• 13 posts
2 Vehicles
Posted:6/11/2003 19:02
Thanks for the help, my motor has 99,000 miles on it.
topfisherman
• Unknown, WI, USA
• 13 posts
2 Vehicles
Posted:6/11/2003 19:41
I read on another web site that the valve guides could have wore down and be the problem, but wouldn't that lead to the engine having bad compression? When I did a compression check, the numbers for each cylinder were only 5 psi apart from highest to lowest.
harold kempf
• nampa, ID, USA
• Registered on 7/6/2003
Posted:7/6/2003 17:52
did you check the pvc valve?
topfisherman
• Unknown, WI, USA
• 13 posts
2 Vehicles
Posted:7/9/2003 16:20
Yes, I checked the PCV valve and replaced it twice. Thanks for the help so far, keep posting.
sadisticglee
• washington court house, OH, USA
• Registered on 11/16/2003
Posted:11/21/2003 14:23
did you check your air filter to make sure is was'nt saturated in oil if it is the oil will get sucked into the intake
