2nd time around Cooling fan issues
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 446
Rev Edward Lister
• Henderson, NV, USA
• Registered on 1/11/2012
• 13 posts
Posted:3/5/2012 14:37
I have a 2008 CVPI. Last summer, I had to replace the cooling fan. Spent $350. Now the car is exhibiting the same symptoms. No Fan even with AC on. I ran a jumper, the fan runs. Does Anyone know how to bypass the Module (relay?) between fan motor and power supply? I live in Las Vegas, and don't mind having the fan run on high all the time.
Thank you
Rev. Edward Lister
edited 3/6/2012 12:53
blwcorp
• Springfield, MO, USA
• Registered on 10/11/2010
• 19 posts
Posted:3/10/2012 21:34
Maybe the engine is running cool enough that it doesn't need the fans. Check the coolant temp. It can be around 230 degrees if it's flowing properly.
Rev Edward Lister
• 13 posts
Posted:3/13/2012 15:30
I read that if you put the AC on, the fan comes on automatically. Besides, it overheated when my wife sat idle with the AC on, and No matter what I did, I couldn't get that fan to run, even when the motor was clearly hot. I am fairly sure the relay (HI/LO) that is attached to the fan assy. even though I put it in last Sept. has gone again. I wish I knew how to test it. I am now considering putting in a lit rocker switch and running the fan manually. I live in a VERY hot environment 110+ in the summer. I tested the fan, and it runs when I run 12V straight from the battery. The relay would be another $110, and who knows how long it will last again? I really just need to know what amp fuse and guage wire plus the amp rating on the switch?
Rev. Edward Lister
