WAVE1200
DIX HILLS, NY, USA |
Registered on 5/11/2012 |
5 posts |
Posted:5/12/2012 16:54 |
Hello everyone. I'm new to the forum. I have a 1998 crown vic that has had this noise for a while( maybe 20.000 miles or so and I'm lost . Near the end of the video to make noise go away I stated that i put the car in drive to make it go away, I ment to say i put it in park. Also to bore scope I could not get it all the way up to the flex plate bolts to see any cracks. After I unbolted the flywheel to see if I could see a crack when I bolted the flywheel back up it makes this noise a little louder when the car is first started up in the morning in park and goes away after about 2 minutes. Also sometimes the noise is louder than other times. I have replaced timing guides and i would be upset to remove the transmission to find out the flexplate is good http://www.youtube.com/watch?v=e9taJGnTNRQ&feature=youtu.be |
