No throttle cable on 2006 CVPI?
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 610
MyFordAgainstYourHonda
• South Florida, FL, USA
• Registered on 9/9/2012
• 26 posts
Posted:9/16/2012 14:33
I noticed while i drive my car accelerates normally until it hits 1,000 RPM at 40mph, it seems like the car goes into a low gear, thats the only way i can explain it. Someone told me that theres a digital throttle sensor for the 2006 model, where is it located and whats the exact part called?
hondaclf
• Baldwin, NY, USA
• Registered on 2/25/2009
• 244 posts
4 Vehicles
Posted:9/16/2012 15:06
You have "drive by wire", everything from the gas pedal to the throttle body is electronic.
If there was a fault in the system, you should get a fault code(CEL).
You can try resetting the sensor by going through a series of steps:
- turn the ignition key to the -ON- position, but DO NOT START the vehicle.
- slowly depress the gas pedal to the floor.
- quickly release the gas pedal.
- turn the ignition key to the -OFF- position.
- Repeat the above 4 steps, 2(two) more times.
edited 9/16/2012 15:07
• 26 posts
Posted:9/16/2012 19:17
I just did the test on my car, i didnt drive it though. Was i supposed to have it hooked up to a computer while i did the test?
