1999 cv
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 705
scottgalpin
• other, XX, Canada
• Registered on 9/24/2012
• 7 posts
Posted:9/24/2012 16:52
my power steering pump was leaking through the plastic part for the plug , the plug was broken off , anyways so i replaced the pump itself and then with out raising the wheels off the ground started the car poured the fluid in then tried steering the wheel , well now the replaced pump is leaking at the same spot and i cant get rid of the air , so now i am wondering if i damaged the pump by not lifting the car first and should have i not started the car before i tried getting rid of the air , thanks in advance
Posted:9/24/2012 17:58
If you followed the procedure as outlined in the Chilton manual (https://elibrary.mel.org/validate?url=http%3A%2F%2F0-infotrac.galegroup.com.elibrary.mel.org%3A80%2Fitweb%2Flom_accessmich%3Fdb%3DCHLL), you should okay. If not, you have to replace the pump again.
jwar1127
• lauderhill, FL, USA
• Registered on 5/28/2009
• 47 posts
Posted:9/25/2012 17:16
you can get the air out by turning the wheels left and right all the way lock to lock. As far as the leak in the same spot i would double check the area.
1999 cv
