99 Crown Vic 4.6 Engine Rattle
Thread Statistics:     Users to Post: 3   |   Total Posts: 4   |   Total Views: 893
firstfordever
• Monee, IL, USA
• Registered on 10/18/2012
Posted:10/19/2012 11:12
Hey I have a rattle that I can not figure out it sounds like its coming from the front passenger valve cover here is a link to the engine running and making the noise...it is not constant ....
http://www.youtube.com/watch?v=jEF3U5WF4HM
Posted:10/19/2012 14:45
Have you tried pin pointing it with a mechanic's stethoscope? Or you can use a length of fuel line to your ear and listen with the other end close to the noise. You can spot exactly where the noise is coming from.
Also, when was the last time you did a tune-up. If its been over 50K miles, replace plus, filters, and pcv valve.
firstfordever
• Monee, IL, USA
Posted:10/19/2012 14:56
I just replaced the plugs coil packs fuel and air filter the idler and tensioner pulley it has 95000 on it car runs perfect but the noise is there here and there, I just changed the oil and used Valvoline synthetic and a bottle of Lucas oil treatment might of helped a lil bit
rss459
• Livonia, MI, USA
• Registered on 12/30/2012
• 13 posts
Posted:1/2/2013 12:44
Wow just ran across this post nosing around and by golly the youtube video that is pointed to is one I made on my car and is in my account. I can only hope it is being used as an example which is fine. Just curious however.
Oh FYI solved this: AC Clutch
