Coil spring rotated out of position on control arm
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 619
windboater
• Hollywood, FL, USA
• Registered on 7/16/2011
Posted:11/21/2012 08:01
I replaced the upper and lower ball joints and bushing on my 1999 Crown Victoria. I noticed that the base of one of my sprigs is not properly seated on the lower control arm . the end of the coil is not sitting in the lowest point of the control arm where it should be. Will it eventually rotate the 3 inches or so to re-position itself properly or will I have to drop the lower control arm again? .
Sunfish
• Nashville, TN, USA
• Registered on 11/12/2012
• 7 posts
Posted:11/21/2012 08:16
You should be able to compress the coil enough to turn it. Some parts places have loaner spring tools available. Be careful and go slow. Sunfish
Posted:11/21/2012 10:50
By removing the shock, you should be able to get a spring compressor tool inside and compress that spring enough to rotate it.. I screwed up when I rebuilt my front end, and had to do this. The guy at AutoZone "swore" I would have to remove the A-arm. Didn't happen!
