2150 Carb on 1984 ford 250
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 1309
rb33
• Cove, OR, USA
• Registered on 12/3/2012
Posted:12/3/2012 16:37
I-m working on a 84 , 250 W/ automatic that has been run very little for the past several years. I took the carb off and had it rebuilt and installed a manual choke. It starts right up but does not want to idle. Other than the two adjustment screws on the front of the carb which are air adjustments I believe. Where is the idle adjustment screw.
pnp522
• Lompoc, CA, USA
• Registered on 9/2/2012
Posted:12/3/2012 18:11
check for vacuum leaks. There may be one around the gaskets. Also the plastic and rubber vacuum lines get brittle and crack.
