Low beam highlights and horn issues on 1989 Crown Vic
Thread Statistics:     Users to Post: 4   |   Total Posts: 4   |   Total Views: 626
topgun9
• Redwood City, CA, USA
• Registered on 12/6/2012
Posted:12/9/2012 09:00
Low beams refuse to come on, but high beams will work. Horn goes off for no reason while the car is sitting. Any ideas?
curemode2002
• Lehi, UT, USA
• Registered on 3/8/2012
• 147 posts
Posted:12/10/2012 09:04
Sounds like a short under the dash possibly in the column. The low beams could also just be a bad light switch (this is fairly common) but with the horn you have something making contact that shouldn't. Check the horn setup in the wheel first as they can become loose or just gunked up with something that conducts electricity.
plstktnkr2
• Reisterstown, MD, USA
• Registered on 7/27/2011
• 13 posts
2 Vehicles
Posted:1/6/2013 22:00
i too have a headlight issue, but my hi-beams will not stay on, and the lows will not com on at all. any suggestions?
1966 Lincoln 'vert
1985 Lincoln Hearse
1983 Mustang 'Vert
cw3131
• radcliff, KY, USA
• Registered on 1/28/2013
Posted:1/28/2013 08:35
lol i knew i wasnt the only ones with that problem. ok, so apparently ford had this problem alot with the 88-91 crown vics.. why? no idea..
so i took mine to the Ford dealer and i was told i needed to replace the steering column. they would then arrange the wires so that they arent touching each other... you guys might have had a burnt smell... that was the case with mine.
