Forums > SuperMotors Community Discussion > Upgrades and Aftermarket
Lincoln CFI to carb swap
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 2323
manic_mechanic6663
• Salt Lake City, UT, USA
• Registered on 2/18/2013
Posted:2/18/2013 10:48
I have a 1984 Lincoln Town Car. It has CFI on it, and I have been considering swapping it to a carburetor. I am planning on using a Edelbrock Performer intake manifold, a Performer 500cfm carb, a mallory dual point distributor, and an Edelbrock Performer Plus cam shaft.
What I would like to know, can I use the stock in the tank fuel pump for this project with a fuel pressuer regulator? Or should I use a mechanical fuel pump? What about connecting the TV, and kick down rod for the AOD?
Anyother advice that I could get on this subject would be greatly appreciated.
Posted:2/18/2013 14:58
Being you want to go to a carburetor, you will need a fuel regulator to reduce the fuel pressure to work with the carb. Take look at http://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=499140 to see. The fuel regulator will need to be put inline before the carb.
Here's another example: http://forums.corral.net/forums/5-0-5-8-engine-tech/359786-need-1985-5-0-hp-specs.html
You may want to do more research on Thunderbird, Crown Victoria, and Mustang forums looking into this swap. Lots of luck to you on it.
edited 2/18/2013 15:04
manic_mechanic6663
Posted:2/19/2013 20:15
I've noticed that there are two fuel lines going to the throttle body. Could one of them be a return line?
