88 crown vic 5.0L engine upgrades
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 2565
59ranchero
• Tulsa, OK, USA
• Registered on 3/23/2013
Posted:3/23/2013 22:21
I have an 88 crown vic donor car with 52K on it. Runs great. Specs say it only has 150 hp and 270 lb ft torque. I am planning on putting the engine and aod tranny in my 59 ranchero and wondered whether to keep the efi injection/computer or go back to a carb setup for power. Didn't know what mods to make on an injection engine to make power. Would like 250-300 hp, will be a daily driver
Posted:3/24/2013 04:42
Congrats on trying out a great idea. Engine transplants are fairly common. I've put Chevy, Ford, and Olds engines and trannies into VWs in the past.
1) Search out as many different forums as you can looking for info about this type of swap. (Wish I could have done it in the past before Internet.) Concentrate of Mustang forums, since they would have the most info about rebuilding / upgrading the engine.
2) Search hot rod magazines online, like http://www.mustang50magazine.com/index.html, http://www.musclemustangfastfords.com/index, or http://www.hotrod.com/. You should be able to find articles or how to's about the engine. Maybe a few about a swap or two.
3) Start looking at catalogs, like SpeedwayMotors.com for specifics you may need. The Ranchero came with a Straight 6 or 352 ci V-8, so you may need adapters to mount the 302 onto the frame. The same with the AOD. There are several "adapter: companies out there. Speedway Motors was the first to come to mind.
4) Start taking pictures and document the swap. Whenever you get a chance, post the swap as you go along online. You may be able to help someone else. Or may have a problem that somebody knows how to help you with.
Best of luck and have fun. It's a dirty job, but somebody has to hot rod it.
woodytorinoo
• New florence, MO, USA
• Registered on 4/14/2013
2 Vehicles
Posted:4/14/2013 09:17
Stroke it , I did a 92 Lincoln mark 7 5.0 H.o. took off valve covers and Wow said CRANE CAM with roller rockers and a ford oval sporting a f4xxx part # so , I take efi off, go holley Street dominator intake, with 675, double pumper intake Lunadi voodoo cam,, High rev, 289 rods , badger pistons .030 over, use 390 oil pump shaft ... original 289 dizzy , press a 351 firing order Msd Gear. arp bolts moroso covers , oilpan factory ford mark vii shorty headers ,double roller chain, top notch to start with when junck yard pulled this engine out of a wrecked mark vii lsc , I say go points , its a old car maker look that way , yea chokes can suck n the winter , but r u gonna drive it daly in bad snow/ice,and if u are drivn far everyday to work go efi -maf and not speed density , , I have done all 3 I had hard time with the speed density and the big cam, the efi was ok but hood was still a problem in my 64 galaxie 500 so finally I went back and did it carb and a c-4 with 68 bell on a 66 falcon crusie o matic 50 oz fly wheel off e bay 60 bucks buy sfi and I never had dynod but I ran 14 BTDC 373 trac loc 9 inch .
I really felt like I had a 351 c with a Drag Pack Sucker had seen 6000 on the tac and broke engine mount trans cross member cracked once ,then cracked a axle tubing at there common weak spot, butt all stuff that u work out when Ruff housn Built my own belt system with reverse rotation water pump,,, go to auto zone buy Greg reed book parts interchange for the ford small block , theres always sumthin u wouldn't think ,,,,,,, Go Carb Thumper cam ,,,, Or hit u tube up and Check out the CLEAVer engine that's a build a Boss at home
