HEEEELP!!!
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 436
thizzital
• bakersfield, CA, USA
• Registered on 4/28/2013
Posted:4/29/2013 13:16
My 2007 P71 is stalling at red lights, plus the a/c goes from cold to hot then back to cold. any suggestions on a fix.
curemode2002
• Lehi, UT, USA
• Registered on 3/8/2012
• 147 posts
Posted:4/29/2013 13:45
I would look at these two things first since you mention the AC and Stall together.
1. The AC Compressor is working to hard due to low pressure in the system. (if it is constantly kicking on and off and cycling the AC solenoid this can cause your car to stall.)
2. The AC Compressor Clutch or Compressor is failing and causing the pulley to lock up. (this can definitely cause your car to stall.)
The first is the most likely as the system gets older it can develop leaks that cause a need for an AC Service. The second happens when you don't get a service and allow it to continue causing issues or running low on oil in the system.
Usually you can get a purge and fill for around 100.00 they will usually hit it with dye in the fill so they can use a blacklight to check for leaks this will also relube the system.
edited 4/29/2013 13:46
HEEEELP!!!
