razzi
• Milwaukee, WI, USA |
• Registered on 12/14/2012 |
• 28 posts |
• 1 Vehicle |
Posted:6/12/2013 06:59 |
Hi Guys!
I have a 2003 CVPI. I am going to replace the struts, shocks, lower ball joints, connecting pins, and control arm bushings. I was probably going to go with Moog for the ball joints, but I need suggestions for the struts. Do they make a complete strut assembly? What/where is a good place/store/website to purchase them? Any other suggestions and tips would be appreciated, first time really wrenching on the car. Thank you!!! |
Posted:6/12/2013 14:03 |
I'm sending you a link to www.crownvic.net about the front suspension
http://www.crownvic.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=2176934
I've used AC/Delco front and rear shocks because they handle better than others. Of course, they are truck parts being used on the CVPI.
For struts and strut assemblies, I would search several of the forums, like www.crownvic.net or www.crownvic.ca to see what others have to say. also, you may want to check out the Mercury Marauder (www.mercurymarauder.org ) to see. A lot depends on what you are using the car for.
Road racing, slalom racing, auto cross uses a different setup than drag racing does.
Posted:6/12/2013 17:20 |
Best choice for front and rear is KYB Gas-a-Just:
Front - 551602
Rear - 555603
Shop around, I got mine from Amazon.
razzi
• 28 posts |
• 1 Vehicle |
Posted:6/14/2013 11:52 |
Thanx a lot jdmeaux for your input! You answer a lot of posts. Its nice to see that. I just ordered KYB struts and Moog ball joints/stabilizer bar links from Rock Auto.com. They seem to be the most reasonable. Thanx again. |
razzi
• 28 posts |
• 1 Vehicle |
Posted:6/14/2013 11:53 |
Thank you hondaclf. I took your advice and ordered the KYB struts from Rock Auto. Thanx again. |
