Which wire do I cut in a 2000 Police interceptor?
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 717
TWH
• Des Moines, IA, USA
• Registered on 6/14/2013
Posted:6/16/2013 08:10
I'm installing a kill switch. I took off the ignition casing under the steering wheel and I see 5 colored wires running away from the ignition(white, orange/white, black, purple and blue).
There is one thick black/purple wire running to the ignition and another black wire running to the ignition too.
Which wire do I cut to connect the kill switch? I just want to disable the starter wire only.
Posted:6/16/2013 15:44
Try these two websites for wire colors.
http://alarmsellout.com/support/diagrams/vehicle/FORD%20CROWN%20VICTORIA%201991-2005.pdf
http://www.automotix.net/autorepair/diy/2000-ford-crown_victoria-wiring_diagram.html
I hope this helps some.
Here's another
http://www.the12volt.com/installbay/alarmdetail/827.html
These are links you may want to bookmark for future use.
edited 6/16/2013 15:46
TWH
Posted:6/17/2013 11:56
Thanks man. Great information!
I identified the starter wire white/pink on the wiring diagram but don't see it under the harness in my car. The wire black/purple is not even listed and that's the wire the runs to the ignition. But I don't want to take any chances by cutting the wrong wire. I will take it to the Ford Dealer.
