F-150 4.9L 300 CI 6 cylinder Skips, misses under load
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 1572
rebranger
• dundee, MS, USA
• Registered on 1/22/2011
Posted:8/3/2013 15:33
Put a code reader (static test, engine not running) on it & it came up with the following codes:
P0174 Bank 2 Lean
P0161 ??
P0306 cyl 6 misfire
P0141 O2 Heater Bank 1, Sensor 2
P0118 Coolant temp, sensor circuit, Hi Voltage
SO, I replaced plugs, wires, including coil wire, rotor & distributer cap, still does it. skips, misses under load (acceleration)
NEED HELP?
What else do I need to replace?
Posted:8/4/2013 04:06
On any missing, ALWAYS start to check for a vacuum leak. Plastic or rubber hoses do not last forever. Heat and cold extremes will cause them to crack. You can use brake parts cleaner to spray lightly around the hoses. When the rpm's change, you found the area to search in.
