Forums > Frequently Asked Questions > Registry Entry Questions
CNG 2000 Crown Victoria Repair Help Fuel Code P0192
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 3953
pocozocko
• Norwalk, CA, USA
• Registered on 8/9/2013
Posted:8/9/2013 17:01
I have a 2000 CNG(Compress Natural Gas) it is the gas that is Prices $2.00-2.50 per gallon in California.
Well I bought a 2000 Crown Vic. It had no Fuel rail and Sensor(Fuel presser that is on the Fuel rail.
I bought a used one from a Place in Anaheim, All Ford Junkyard. So they had on when called. I went down their and the place has ALL I could need and the $216 CNG fuel presser sensor. That is a reasonable price for a item that is not even listed on eBay(check facts Yes their is 1 on line for $600)
I have had the Computer reset 3 times the car runs good but will not bass the Cal. Smog test for Fuel presser sensor Low. The car runs good 100-150 per tank(10 gal)
When I turn the key on in the A.M. I see the Check Engine Light flashes on like it should with all the Lights that come on with the First key turn. after I run the car the Next time I restart the car,
No Check Engine Light flashes on then.
But I keep getting theirs error. SO is their a reason IF! THE ONE I BOUGHT WAS BAD the car seems like it is running 1-10 it is a 8.
Could the sensor have field in either a open or close position that would read a Code P0192 have no-little effect on the car. The Junk yard said it comes of a running car BUT when I unplug the sensor The Car has no stress trying to run and Nothing seems to fail just keeps running smother.. What the Hell I have been told that If that CNG Fuel Presser Sensor fails the car shakes and rattles and will not work well.
Thank You
Poco Zocko
CNG 2000 Crown Victoria White
Please anyone have and Good questions about the details or reasonable answers please reply. Any just J.A. no need to reply .
pocozocko
• Norwalk, CA, USA
Posted:9/20/2013 17:58
I Bought a New aftermarket Serener. It was from ford and the installation instruction included my 2000 Crown Vic. I installed it and Still have the same error after resting the Computer. I still do not have the Check engine light coming on Unless I turn the Key Slowly.
Please any help is good help.
patahhati
• jakarta, CO, St. Lucia
• Registered on 1/19/2016
Posted:1/19/2016 22:16
thanks for the information may be inspired
Penawaran referensi informasi Jual dan service Sofa bagi anda yang saat ini memerlukannya.
