question on a flashing OD light on 2000 crown vic p71
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 3121
roger330
• phila, PA, USA
• Registered on 10/10/2013
• 9 posts
Posted:10/13/2013 00:21
The other day I had my crown vic sitting in my drive way idling all the sudden I notice my OD light starts flashing so I shut the vic off then start it back up now I have a check engine light and flashing OD.so I take the car for a spin and notice it is pulling away in second gear and no overdrive. Now I get the car home and wait til the next day to scan it.I wake up the next day go out to the car and start it up NO FLASHING OD but still a check engine light. So I scan the car and get codes po708, po720, po743, po750 then erase codes drive the car all day with no problems until that night flashing OD. Now I replaced the vehicle speed sensor and output speed senor and reset computer and still I get a flashing OD. After replacing the two sensors later that night I have the car idling in my drive way and all the sudden the OD light stops flashing.
Can someone help me with tips on what my next thing that I should try I really dont think the trans is bad it just seems like its something sensor or computer what do you think ??????
Can a neutral safety switch cause this ?? I hear the fords shifter sensor are a common problem
Posted:10/13/2013 06:04
All these codes can refer to a corroded connection.
http://engine-codes.com/p0708_ford.html
http://www.obd-codes.com/p0743
http://engine-codes.com/p0750_ford.html
I wish people would search for an answer before replacing parts.
roger330
• phila, PA, USA
• 9 posts
Posted:10/20/2013 20:05
Just to let everyone know that is having this problem what I did to fix my problem was change my trans Filter and fluid with mercon V and clean the TCC solenoid on the valve body of trans. Now it works great
