91 F250 5.0 emissions issues or vacum leak
Thread Statistics:     Users to Post: 3   |   Total Posts: 5   |   Total Views: 2377
chefsteele
• Honokaa, HI, USA
• Registered on 11/16/2013
Posted:11/16/2013 11:40
the past few week my 5.0 has been running rich, so rich fuel dripping from my exhaust.
I have cleaned my throttle body, replaced ERG valve and sil, throttel sensor, idle control. traced my vacum lines no leaks. I pulled my intake manifold, cleaned it. plugs, wirs, rotor and cap. the engine ran great for a week, then started running rich again. back firing with a bad smell nasty smell.
this is an EFI
where can I turn next? this my only transportation.
I have a 5.8 block thinking to change it out replacing the 5.0
hopping to hear that it my be somthing simple.
thank you for any sajestions.
chefsteele
• Honokaa, HI, USA
Posted:11/16/2013 22:57
I pulled my cross bar at the back end of my head, it was fully clogged up.
also my ERG pipe that I finally unscrewed was also clogged.
I have ordered a new map sensor, just wondering if I can remove my ac pump that also acts as a smog pump?
chefsteele
• Honokaa, HI, USA
Posted:11/16/2013 22:59
I am concerned thst I might be posting in the wrong thread, nobody has made any comments
edited 11/17/2013 10:19
BigDangFord
• Chandler, AZ, USA
• Registered on 3/11/2015
• 42 posts
Posted:4/19/2015 16:10
sounds like you have a major problem. are your compression readings normal?
does it have a catalytic converted exhaust?
your EGR system may be wrong causing the enriching and soot.
Bear79
• Stephenville, TX, USA
• Registered on 7/5/2016
• 12 posts
Posted:7/6/2016 11:39
I would check the PCV valve and filter. If I am thinking correctly there is a filter in the intake. Looks a lot like course steel wool. They get clogged up and cause drive-ability issues.
