Shawn76
• Terre Haute, IN, USA |
• Registered on 11/25/2013 |
• 2 posts |
Posted:11/25/2013 11:09 |
I am having problems with the heat/AC. The heat blows out of the front vents even if it is set to floor or defrost. It does blow some air out of the defrost/floor but it cold air,the air from the vents is warm,not hot.
I have changed the EATC unit and Blend door acuator and still have the same problem. Any idea where I should look next?
It has 151,000 miles on it but runs great! I have other problems to fix on it. Needs idler arm,master cylinder and EGR Tube fixed,has a hole in it right before it goes into the exhaust system. I didn't pay a whole lot for the car,under $1000 and I know it should get over 250,000 miles on it easy. That's why I bought a Crown Vic,I work for a taxi company and we had some 2003's that had over 350,000 miles on them and currently have a 2007 with 271,000 miles. |
