oil in the plug well
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 912
tclay
• earlville, IA, USA
• Registered on 12/1/2013
Posted:12/1/2013 06:42
I have a 1999 crown vic police interceptor I was changing the plugs and found oil in the plug well next to the firewall( drivers side) I was told a cracked head . she runs good any ideas on how or why the oil is in there?
Posted:12/1/2013 07:46
Check for leaks in hoses. Possibly oil from the PVC valve leaked there, if it is on that side. Or a loose valve cover, or bad gasket.
Check those out before swapping heads.
Bertini
• linyi, AR, St. Lucia
• Registered on 1/2/2014
Posted:1/2/2014 21:30
There is an O-ring that seals the spark plug well and keeps oil from leaking into it. As with any valve cover gasket, it will start to leak over time. Sometimes tightening the valve cover bolts will stop the leakage, but more often than not the valve cover gasket, and well seals, will need to be replaced.
CAR OBD2 SHOP
