2004 CV Stays Engaged
Thread Statistics:     Users to Post: 2   |   Total Posts: 5   |   Total Views: 413
nawspider
• Yukon, OK, USA
• Registered on 12/24/2013
Posted:12/24/2013 01:26
I have a 2004 Crown Vic and it just developed a new problem. The starter will kick in as soon as the key is turned on and will not disengage.
curemode2002
• Lehi, UT, USA
• Registered on 3/8/2012
• 147 posts
Posted:12/24/2013 06:13
That is typically caused by the Switch at the base of the lock cylinder slot. Under the lock cylinder there is a multi-position switch used to turn on power to the car, start the car, or provide power to the accessories only. If this switch has rotated in its seat or has started to break apart it will cause this issue. You will need to remove the steering wheel and column cover to get the lock cylinder out to inspect/replace the switch.
nawspider
• Yukon, OK, USA
Posted:12/24/2013 08:56
I think that you are spot on. I was able to remove the steering wheele but I am having truble removing the switch. The key will not remove or i shoud say the lock cylinder will not remove
edited 12/24/2013 09:32
nawspider
• Yukon, OK, USA
Posted:12/24/2013 21:39
I had to replace the steering column the shaft had broken and prevented the key from being able to remove. I have replaced it and the darn thing still tries to start when it is in park and the key is in the run position. I did replace the ignition switch but still no luck for me. Does anyone have any ideas?
edited 12/24/2013 21:40
curemode2002
• Lehi, UT, USA
• 147 posts
Posted:1/3/2014 07:30
The only other things I could think of would be the Starter Solenoid may be stuck, or there is a short in the electrical lines.
