Power Sterering leak
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 664
Prover1964
• Saint Petersburg, FL, USA
• Registered on 2/9/2014
Posted:2/9/2014 04:16
I have a 1997 Mercury Grand Marquise with 110k. I love this car. I noticed a small leak on the driveway and the power steering started dropping its level. It is hard to tell were it is leaking because it is so slow. What is the more common issue the pump or hoses.. ?? is there a way of pinpointing the leak.
curemode2002
• Lehi, UT, USA
• Registered on 3/8/2012
• 147 posts
Posted:2/10/2014 09:15
Most commonly it is one of the hoses. However it can be where the reservoir connects to the pump. The seals in the pump and the steering box can fail but it is rare and usually quite messy.
Pinchas
• zibo, CO, St. Lucia
• Registered on 3/2/2014
Posted:3/2/2014 22:13
rom my experience, the are several steps to stop power steering fluid leaks. The first step is to find out where the leak is in the hose or gasket. Then, with power steering fluid, pour in an additive called stop leak. If this doesn't work, you can purchase gasket sealant or replace all the gaskets. Lastly, you can replace the pressure hose if the leak is in the hose.
OBD2 Code Scanner
