05 Crown Vic PI won't crank
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 505
Natedog42
• Durham, NC, USA
• Registered on 2/21/2014
Posted:2/21/2014 09:52
I have an 05 crown vic PI, and it occasionally won't start while in park. When I turn the key, I usually
get nothing, but sometimes it roars to life as normal. It always starts in neutral. Battery and fuel levels are within normal limits, so it shouldn't be a battery problem. Any ideas? Similar problems? Thanks all!
Slow your roll
razzi
• Milwaukee, WI, USA
• Registered on 12/14/2012
• 28 posts
Posted:2/21/2014 10:22
Could be a bad wire going to your starter. Or, it could be the starter itself.
edited 2/21/2014 10:23
dbmcd
• Los Angeles, CA, USA
• Registered on 10/12/2001
• 69 posts
1 Boat
4 Motorcycles
11 Vehicles
Posted:2/21/2014 11:27
If it always starts in neutral, then it is the circuit that tells the car that it is in Park and that it is ok to start. Maybe called a safety switch. Jiggle the shift lever and see it it starts then. Probably a loose connection or dirty contacts. Could also be in the LCM or Lighting Control Module, which controls a lot more than just lights...
