Driver door lock actuator?
Thread Statistics:     Users to Post: 1   |   Total Posts: 2   |   Total Views: 364
SamHouston
• Houston, TX, USA
• Registered on 6/14/2014
• 8 posts
Posted:7/24/2014 17:03
Hi all,
I just bought an 05 Grand Marquis. All doors except the driver's can be locked/unlocked with the remote. I can see the movement and hear the click on the driver's door but it won't lock or unlock. Same observation when I use the keypad. Thankfully the driver door still works fine with the key.
Is this a common problem? Is there a fix? Hopefully a quick and easy way.
Thanks in advance for sharing your experience.
Sam
SamHouston
• Houston, TX, USA
• 8 posts
Posted:8/1/2014 07:20
Knock, knock... Is this forum always this active? (Yes, sarcasm.)
Anyway, I found the problem. The actuator is still good, but is no longer attached to the door. It's hold by a single rivet and the rivet isn't there anymore. I'll have to remove the door panel and see if it can be re-attached.
Feel free to contribute if you have experienced this problem before. Thanks.
