1996 lx vic Oil pressure switch/oil filter housing part spraying oil.pressure relief valve?
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 543
96lx
• SACRAMENTO, CA, USA
• Registered on 1/9/2019
Posted:1/9/2019 08:43
Hello I have a 1996 crown vic that I changed the oil pressure switch. When I screwed it in the part you screw it into broke inside now it lets oil go straight down through it.It almost looks like a pressure relief but I need to know if that is a separate part or is it part of the oil filter housing.
hondaclf
• Baldwin, NY, USA
• Registered on 2/25/2009
• 244 posts
4 Vehicles
Posted:1/9/2019 11:37
The oil filter and the pressure sender screw onto the oil filter adapter which is bolted to the block.
I have broken off an adapter in the pressure hole and gotten it out with an extractor so that may be an option.
you can certainly remove the filter adapter if you need to in order to remove the broken off part of the pressure sender or replace it if the actual adapter is broken, make sure you have an new gasket ready, there is a gasket between the adapter and the block(there is one for cars with an oil cooler and one without so make sure you get the right one)
