GW2011
Baton Rouge, LA, USA |
Registered on 12/22/2023 |
1 post |
Posted:12/22/2023 15:05 |
I have a 2011 Mercury GM. After, partially removing the dash board and dropping down the steering wheel column to replace the AC blend door, my steering column partially separated and the inner rod or shaft disengaged and now I cannot put it back together. I know that I damaged the clocskpring because , the steering wheel rotated freely so that is also another issue but now I have absolutely no steering.Is there any tutorial or help with this? Appreciate any help in advance! |
