Josh Morris
Winlock, WA, USA |
Registered on 11/4/2003 |
2 posts |
Posted:11/5/2003 14:22 |
can and one help me out i have a 82 bronco with a 351W that i just re built and i am looking for some more affordable horse power i have an RV cam and headers as well as a 600cfm 4brl carb is there any thing else that i can do to get more power |
Drew Hardrath
West Valley, UT, USA |
Registered on 10/20/2003 |
33 posts |
Posted:11/12/2003 18:53 |
Theres a few things, such as : K&N Filter, Uprgraded Ignition ( and not just plugs and wires, but a new/ higher output coil, igniton box, such as an MSD 6A or 6AL, ect...), Cat back exhaust will run you about $250, which is about what i paid for my 3 inch Flowmaster, headers are also pretty cheap, seein as how you dont need AIR tubes, you could pick up some Holly FlowTecsh for about $90. Out of all these i would do the filter ( if you havent already) the headers and the exhaust system, the exhaust and headers will really help you notice your cam, and improve the way it sounds as well!
Edit: whoops, kinda spaced on the part where it said you already had headers, my bad. in that case, if you havent upgraded the rest of the exhaust system, then goin with larger diameter pipe and a good muffler will help uncork some of the power lost after the headers. |
Kevin Furlong
Central Valley, CA, USA |
Registered on 3/25/2004 |
1 post |
Posted:3/25/2004 20:27 |
You might consider putting in some electric fans and dumping your power robbing standard engine fan, the electrics will get you about 20 rwhp. This is about the best bang for the buck out there.
If your serious about getting a considerable amount more HP, then you might statr saving your nickles for a set of AFR or Edelbrock Performer aluminum heads. You could always have your iron heads ported also.
A aftermarket ignition box would be a waste of $$, you wont get any HP there. It's a good product if your using forced induction or NOS, they have the timing retard funtion in them for these applications. |
