Karl Kraynanski
Plains, PA, USA |
Registered on 12/26/2002 |
3 posts |
Posted:11/29/2003 18:47 |
I looking for help to solve my Check Engine light problem.
I pulled a 326 code, low volts to the DPFE sensor, with a scanner. I changed the EGR valve, cleaned all the EGR ports under the throttle plate elbow and installed a new DPFE sensor, but the same code keeps coming back.
Any suggestion?
The engine pings when the check engine light goes on so I'm not sure if the EGR problem is causing the problem or bad O2 sensors. I haven't pulled any codes for bad O2 sensors.
Any help would be appreciated!
KK |
