N/A N/A
• CHICAGO, IL, USA |
• Registered on 12/2/2003 |
• 1 post |
Posted:12/2/2003 17:42 |
I HAVE A 92 BRONCO WITH THE BW 1356 ECTRONIC SHIFT ON THE FLY. I CAN GET THE 4x4 TO LIGHT UP AND WORK PUT NOTHING HAPPENS WHEN I PRESS 4 LO, THE BUTTON DOESN'T LIGHT UP EVEN? I CAN HEAR THE LITTLE MOTORT ON THE T-CASE TURN WHEN I PUT IT IN 4 HI BUT NOTHING IN 4 LO. WHATS UP WITH IT? |
Posted:1/6/2004 11:33 |
is the car at a complete stop with the trans in Nutral? if yes, maybe its somthin like your Nuetral safty switch on the trans, you might try pullin the codes to see if it flashes you anything. |
Posted:1/16/2004 22:03 |
My f-150 does that to and i want to know how to fix it also. |
Posted:2/8/2004 21:38 |
dont feel bad my 94 bronco does the same thing. Haven't been able to figure it out either |
Posted:5/15/2004 00:26 |
A couple of things first... Get under the bronco and check out your t-case...are any of the transfer bars rusty? check for broken seals, broken hoses or wires that are just hanging there.
check your fluids.
take some pictures and post them. let us see what you see.
spray WD-40 EVERYWHERE and gently tap all of the transfer bars and shift linkages with a rubber mallet, spray with WD-40 AGAIN!!! repeat lather and rinse!!!
last but not least... have a friend get under the bronco and get right next to the t-case and look/listen to the t-case when you attempt the shift. have him describe what he hears or sees happening.
it will go a long way towards helping us/you out. |
Posted:10/7/2008 19:03 |
I had trouble with my B&W 1356 electronic transfercase. So I made a video of my trouble shoot along with some links I found on-line. I hope this will help you out.
http://au.youtube.com/watch?v=OD2xuJ0kMKA |
BigBronc1989
• lakewood, CO, USA |
• Registered on 1/13/2009 |
• 1 post |
Posted:1/14/2009 09:40 |
my 89 bronc doesnt do that it shifts into 4 lo and then there are about four or five loud ass knocks, but sorry with i couldnt help you out. |
