John Williams
• Destin, FL, USA |
• Registered on 12/22/2003 |
• 1 post |
Posted:12/22/2003 12:45 |
We have got a '96 Lincoln town car and the Air Suspension light has come on. The back of the car does not raise up when started or put into gear. How much does this cost to fix or can i do it in the driveway? Thanks
John S. Williams |
KULTULZ
• ROCKVILLE, MD, USA |
• Registered on 9/30/2003 |
• 9 posts |
Posted:12/24/2003 00:30 |
[b]-START HERE-[/b]
There are spring conversion kits if you decide to go that way. |
Posted:1/11/2004 21:40 |
Can you hear the compressor come on when you turn the key to on but not start? If not check the switch in the truck that turns the bags on and off. If that doesn't do it check the fuses. Or if you had work done recently and it was put on a lift and the bags weren't turned off it can cause problems when it comes back down. |
