cory ross
San Diego, CA, USA |
Registered on 1/24/2004 |
1 post |
Posted:1/24/2004 17:16 |
My od light started blinking the other day. I looked it up in the book and it says take it to the dealer, something is wrong with your transmission. Well I figure that. I checked the tranny oil and it was fine. not burnt. Truck drive the same as always.
If anyone could give me some advice, I would like to try a few things before I take it to the shop. I just don't know a shop I can really trust. |
miesk5
Coronado , CA, USA |
Registered on 7/23/2002 |
57 posts |
2 Vehicles |
Posted:1/29/2004 17:13 |
yo Cory,
Any symptoms along w/the blink?
You can take it to a mechanic that can ck for codes.
Could be what I had, a short in wiring harness under strg column;
Could be a bad TCIL LED; see this for info on the TCIL - http://www.atcdg.com/TechBulletins/bull_135.htm
Could be the vehicle speed sensor (on rear axle) is disconnected or harness connector is bad, PSOM (Programmable Speedometer - Odometer module) is disconnected or bad or a failed TCC (Torque Converter Control) solenoid. + other thAngs.
Please include your vehicle model, year, engine and tranny in your signature for better replies in future.
96 XL 5.0 E4OD, Man Xfer/Hubs
THANKS to ALL WHO SERVE!
