Posted:2/20/2003 11:37 |
After playing around in the snow last night, my '90 bronco seems to be stuck in four wheel low. Unfortunately, I have the electronic 4 wheel shifter, with an automatic. After playing around with the gear shifter and the buttons, I was eventually able to kick the 4x4 and low gear lights off, yet the transfer case was still engaged. I tried backing up, and going forward again and again while fooling with the buttons, but still nothing. Whats the deal?
-Topher |
Posted:2/20/2003 16:49 |
It could be the shift motor on the side of the t/case got wet and stuck in position. Try tapping on it with the handle of a screwdriver while someone pushes the button. It could also be the control module located inside the passenger kick panel. Listen for a clicking sound while pushing the button. If you can't hear it, check the fuse, or have the module tested.
'80 BRONCO
302, T-18
A FEW MODS |
