351cleveland
Thread Statistics:     Users to Post: 6   |   Total Posts: 9   |   Total Views: 1780
Ike Rettenmair
• Newport, NC, USA
• Registered on 10/10/2002
Posted:1/17/2003 14:19
I was wondering if it is possible or to much work to swap out a 302 fuel injected with a 351c carburated with a c-6 tranny. Is this asking for trouble or is it possible without spending a fortune to do????????????
Kirk Hemmen  Club OwnerSuperMotors Owner
Subscriber since 3/19/2005
• Minneapolis, MN, USA
• 97 posts
1 Boat
4 Vehicles
Posted:1/17/2003 15:06
What vehicle are you doing the swap in? The 351 will give you more torque, but depending on what your goals are, you may be able to spend less money and get similar performance from your 302. It also depends how old your 302 is... if it's starting to age a little bit, and you may have to do a rebuild soon anyway, then it might be worth it. Can't go wrong with more cubes
Kirk Hemmen
- Another self-taught IT guy promising a bill of goods he can't deliver.
Ike Rettenmair
• Newport, NC, USA
Posted:1/17/2003 17:14
It is going in a 1988 Bronco the 302 has 130000 and a rear main leak so sooner or later it is coming out. I drive the bronco daily to and from work and offroad occasionally
Bob Lawrence
• Pittsburgh, PA, USA
• Registered on 1/8/2003
• 11 posts
Posted:1/17/2003 17:26
edited 1/17/2003 17:52
Curt Collier
• Lakewood, CO, USA
• Registered on 12/29/2002
3 Vehicles
Posted:1/18/2003 08:10
351c will bolt up to any trans a 302 will. 351m 400 will bolt up to 429 460 trans.
Bob Lawrence
• 11 posts
Posted:1/18/2003 12:48
Did you ever bolt a Cleveland to a 302 trans? 351C will bolt to 360-390 trans.
Rich Boetsch
• Watsonville, CA, USA
• Registered on 8/1/2002
Posted:1/18/2003 21:56
I have bolted a transmission from a 302 to a 351C as they are both small blocks and have the same bolt pattern. The 351M and 400 both have big block bolt patterns. With all the parts available for 302/351 windsor and engine assemblies available why not go to a complete assembly. You can't rebuild one for what you can buy one for, especially when you consider all factors involved.
• 97 posts
1 Boat
4 Vehicles
Posted:1/18/2003 23:42
Yeah, I have to agree with Mr. Lawrence here... a 351W will definately be an easier replacement and give you more options if you aren't already in possession of a 351c. Like he said, the 351 is basically a 302. Only difference is a longer stroke for more torque. And trucks love torque . Plus, there are a lot of aftermarket parts widely available for the 351w, since it's such a common engine to swap into 79-93 mustangs.
Kirk Hemmen
WD40
• Helena, MT, USA
• Registered on 12/16/2002
• 25 posts
5 Vehicles
Posted:1/21/2003 17:52
Just a couple quick things about a 302 to 351W swap.
The blocks are not the same.
The 351W is taller due to the longer stroke, also making it wider at the top.
Because of that, intakes will not interchange.
Distributors are different as well. 351W has a longer shaft.
Oil pans are also different, due to the different main bearing size.
With all that....what will interchange?
Actually, not much.
Cams, as long as you use the correct firing order.
Most external accesories I.E., water pump, fuel pump(mechanical),
alternator, power steering, valve covers....
IIRC, the motor mounts for the 302 will work for a 351W in a Bronco.
As mentioned before, the tranny will bolt up with no problems,
but you need to use a 351W flywheel.
WD-40 Reverend GripShift
edited 1/21/2003 17:56
351cleveland
