removed distributor cannot retime
Thread Statistics:     Users to Post: 2   |   Total Posts: 2   |   Total Views: 1159
jarrinmi
• romulus, MI, USA
• Registered on 10/30/2009
Posted:10/30/2009 09:02
hello everyone how do i retime dist after removal its a 1993 ford 150 4.9l standard i put no one cyl on tdcdropped in dist to no one on cap it runs but not very good ty sorry but spark plugs went bad ok now
edited 11/28/2009 10:17
eshaver
• Richmond, VA, USA
• Registered on 8/31/2010
Posted:8/31/2010 14:09
O K , put yer finger over the #1 hole . With that done , get yer heper to turn the motor over manualy as you "FEEL " the pressure gaining .
Now stop right there !
Get a screw driver , a long one and see if the screw driver is hitting the top of the piston in it's "Up Right position ". if it is , GREAT! This means that you can now put the distributor at the spot where the rotor should point at #1. If yer on the drivers side , that generally means the rotor should be at or about 4 oclock and pointing down at ya too.
Driving , the most social thing you will EVER DO !
