fordtruck79
• winnipeg, XX, Canada |
• Registered on 12/21/2009 |
• 2 posts |
Posted:12/21/2009 01:10 |
i am having trouble with the vaccum lines on my 1977 f-100. it is a 3 speed auto, with the 400 engine. or 6.6 litre. this is a canadian truck, not sure if it matters. the truck has none of the tomato juice pollution canisters,that most trucks have. my problem is i have a air cleaner with many ports. 1 port for the crankcase vent hose, i have that one figured out. pcv valve, figured that one. now,there are 2 diaphram type things clipped into the body of the breather.these 2 diaphrams are plastic. one is green, one is white, nothing is plugged into these diaphrams.they each have 2 nipples on them. in the top of the air cleaner is another diaphram, this one is metal, also with 2 nipples. on one nipple there is a hose that goes to the air cleaner duct motor. can anyone tell me what vaccum lines get plugged into these diaphrams. does anyone have accurat vaccum diagrams |
eshaver
• Richmond, VA, USA |
• Registered on 8/31/2010 |
• 3 posts |
Posted:8/31/2010 14:04 |
Thye port you're refering to is generaly used with the E G R Valve located under the carburator and the flaper in the neck of the air cleaner . To be truthful with ya , I can't remember if the factory manual has what you need or not . I can send it via the mail. Let me get a printer that actualy prints in the next several days and themn I can actually help ya .
Driving , the most social thing you will EVER DO ! |
