DodgeDiplomat
• Detroit, MI, USA |
• Registered on 1/20/2010 |
• 1 post |
Posted:1/20/2010 19:08 |
Hello, everyone;
After putting gas in my 2000 Crown Victoria (it has 243,000 miles on it) I made a sharp right turn and the motor stalled. It tried to turn over but the motor acted as if it were out of gas. I had it towed to a reliable repair shop as it was closing for the night before realizing that perhaps I should have checked the fuel pump fuse in the fuse box near the battery under the hood. I have a question for everyone: "What normally fails first, the $140.00 fuel pump inthe gas tank or the $1.20 fuse?" |
kylep71
• san jose, CA, USA |
• Registered on 1/28/2010 |
• 1 post |
Posted:1/28/2010 16:04 |
if you have over 200k i think the fuel pump is due for a replacement but maybe try a junk yard beforeyou spend 140 bucks |
rayzorsvic
• Las Vegas, NV, USA |
• Registered on 2/1/2010 |
• 1 post |
Posted:2/1/2010 01:08 |
one thing you can do is pull your old fuel pump and hook a 9 volt battery to it and try pumping gas out of a can. if nothing happens then you have a bad pump. |
luckey
• Toronto, XX, Canada |
• Registered on 2/3/2010 |
• 1 post |
Posted:2/3/2010 10:41 |
Did you try to reset the fuel pump cutoff switch in the trunk?If you had some sort of impact it can shut off. |
