standsalonebrave
Chilliwack, XX, Canada |
Registered on 10/4/2010 |
24 posts |
Posted:11/13/2010 19:30 |
I own a 2003 Crown Vic P71. Has anyone ever used this product?
GForce Performance Chip Kit for the FORD CROWN VICTORIA
WHAT IS IT? The GForce Performance Chip reprograms your air/fuel ratio, ignition timing, and other aspects of your vehicle's engine to SAFELY increase the power, while increasing fuel economy significantly. Our chips are designed and programmed per vehicle. Your car will run smoother, run cooler and more efficiently at the same time. The gains we advertise are real, and are guaranteed with a money back promise. Our chips will not only increase horsepower, but torque as well for more REAL power. It increases power throughout the full RPM range unlike many competitors.
EASY INSTALLATION. Installation can be performed by anyone using simple hand tools. The GForce module installs into your FORD CROWN VICTORIA's engine bay and is connected via 2 wires that plug into the IAT sensor. Diagrams are included. The unit is then able to reprogram the ECU thus improving your car's performance. Everything needed for installation is included in this kit for a quick and easy installation that shouldn't take more than 15 minutes. There is absolutley nothing else needed to have this installed on your vehicle.
COMPATIBLE. The GForce Performance Chip utilizes the latest in automotive engine control technology. Our product allows you to take your FORD CROWN VICTORIA's performance to the next level. Our product is tested to work with your car in either stock or modified trim. You can have any kind of modification and our unit will still remain compatible with your FORD CROWN VICTORIA.
GUARANTEED. Regardless of your driving style our chip will provide a substantial increase in performance in your FORD CROWN VICTORIA. All of these benefits are achieved without disassembling your FORD CROWN VICTORIA's ECU thereby preserving your factory warranty or permanently altering your car in any way shape or form. What sets us apart from our competition is that we offer a solid product that we stand by, so much so that if you are not satisfied in any way we will offer you a 100% no questions asked refund. Additionally, just from the fuel savings alone, our chip pays for itself!
