upgrading my 02 crown vic engine swap
Thread Statistics:     Users to Post: 4   |   Total Posts: 4   |   Total Views: 1410
olan_ade2012
• Suitland, MD, USA
• Registered on 3/6/2012
Posted:3/7/2012 00:41
Could I swap my 02 motor with a year 05-06 motor aslong as I have harness,computer, trans etc ?
Posted:3/7/2012 07:30
If I recall correctly, 2005 was the year they went strictly to 3v engines. To transplant a 05 into older vehicles, you WILL need the wiring harness and PCM. I believe you can use an older trans, but you have to do a tune for it.
You are right about having to replace the engine and trans as a unit with the harness and PCM. It is cheaper in the long run as you are replacing them to run together.
Lots of luck on your project. You need to post some pictures as the project goes along. And let us know if you ran into problems.
hondaclf
• Baldwin, NY, USA
• Registered on 2/25/2009
• 244 posts
4 Vehicles
Posted:3/8/2012 09:31
There was never a 3v engine in a Crown Vic from the factory, none transplanted that I've seen either.
3v 4.6L engines were in the Mustang and the F150.
In '05 Ford went to DBW but that's it.
Just get the newest one you can find and keep the stock engine around since you will need a few parts. The oil pan was changed with the frame redesign in '03.
Rev Edward Lister
• Henderson, NV, USA
• Registered on 1/11/2012
• 13 posts
Posted:3/13/2012 15:44
I wish I had a 3V and I drive an 08'
Rev. Edward Lister
