JThree17
indianapolis, IN, USA |
Registered on 7/23/2011 |
5 posts |
3 Vehicles |
Posted:4/25/2012 09:08 |
Ok in my 2003 Ford Crown Vic I have an issue with my interior lights doorlocks and my radio lights I checked the fuses and everything is fine,does anyone. Know what else to do do?? |
Lafayette, LA, USA |
Registered on 1/5/2009 |
525 posts |
Posted:4/25/2012 09:55 |
First, just don't "CHECK" the fuses. Trying replacing them. Some fuses will go bad and burn at an end where it's hard to really tell. Move the fuse to another circuit with a known good fuse and recheck if the problem is solved. No go? Then its not the fuse. It's in the circuit.
Sometimes the circuit may have a circuit breaker inline and you need to check that too.
With it being the interior lights, door locks, and radio lights, it could be two different circuits, or a power supply issue. Get a wiring diagram and see what wires are in common. That's the place to start. It could be a switch, a contact, or corrosion on a wire end. Check all this.
WIRING PROBLEMS ARE SO MUCH FUN TO FIX.
wizzard1222
Ballwin, MO, USA |
Registered on 1/27/2011 |
139 posts |
Posted:4/25/2012 09:57 |
You'll have to describe the issue in more detail...
Checking the fuses and connections is fine...pull/inspect/replace...even with different ones.
Do you have a model specific electrical diagram ...?
If all else fails...check w/your local library...see if they have offsite or only on site access to their
vehicle database resources...?
Hope that's a starter...
