milnerman
Brunswick, GA, USA |
Registered on 2/15/2010 |
6 posts |
Posted:5/7/2012 15:44 |
I have a 95 Crown Vic that has issues in the passenger front door. The door lock will only manually lock when pushed down by hand and the door handle inside will only unlock it. It feels as if it is jammed. I don\\'t know if this is in the automatic door lock or somewhere else.
I have replaced the door lock actuator and it worked great for a while then it quit work ing went to what is discribed above. The door unlock on that same door will not unlock anydoor except intermittently.
I am trying to see how to disconnect the lock switch on that side but unless you pull the contact pins on the bottom I can\\'t see how to disconnect it.
Also we have replaced the door window motor assembly and it quit working.
Are these doors known for these kind of problems?
Blessings!
Rich
