Brakes Noise
Thread Statistics:     Users to Post: 2   |   Total Posts: 3   |   Total Views: 777
crownvic29
• Washington, DC, USA
• Registered on 5/28/2012
Posted:5/28/2012 18:05
What's up all,
I have a 1993 crown vic, sometimes when slowing down or turning vehicle right I get this rubbing/grinding sound when the brakes are applied at low speed. Please help had pads,rotors, and power brake booster changed still same noise.
Posted:5/28/2012 19:07
Sounds like a bearing or a rubbing backing plate. See if the plate is contacting anywhere (it will be shiny where it contacts). Next step would be to raise the front end onto jackstands, then rotate the tires while applying the brakes. If you get grinding from rotating the tires, bearings are shot.
If you are doing the work yourself, go to www.RockAuto.com for inexpensive parts. And they do have a forum for various vehicles. Also, try out www.crownvic.net for plenty of info on the panthers.
crownvic29
Posted:5/29/2012 05:48
Thanks for the info, CV FOREVER BABIE, I will have that checked out.
Brakes Noise
