scottgalpin
other, XX, Canada |
Registered on 9/24/2012 |
7 posts |
Posted:9/24/2012 16:52 |
my power steering pump was leaking through the plastic part for the plug , the plug was broken off , anyways so i replaced the pump itself and then with out raising the wheels off the ground started the car poured the fluid in then tried steering the wheel , well now the replaced pump is leaking at the same spot and i cant get rid of the air , so now i am wondering if i damaged the pump by not lifting the car first and should have i not started the car before i tried getting rid of the air , thanks in advance |
Lafayette, LA, USA |
Registered on 1/5/2009 |
525 posts |
Posted:9/24/2012 17:58 |
If you followed the procedure as outlined in the Chilton manual (https://elibrary.mel.org/validate?url=http%3A%2F%2F0-infotrac.galegroup.com.elibrary.mel.org%3A80%2Fitweb%2Flom_accessmich%3Fdb%3DCHLL), you should okay. If not, you have to replace the pump again.
jwar1127
lauderhill, FL, USA |
Registered on 5/28/2009 |
47 posts |
Posted:9/25/2012 17:16 |
you can get the air out by turning the wheels left and right all the way lock to lock. As far as the leak in the same spot i would double check the area. |
