cowgirlup13
Canyon, TX, USA |
Registered on 2/28/2013 |
1 post |
Posted:2/28/2013 09:28 |
My trany is slipping between 3rd and 4th gear. Does anyone have any ideas? It will lag then hard shift into next gear. |
MountainWestDiesel
Mountain West, WY, USA |
Registered on 2/25/2011 |
95 posts |
Posted:2/28/2013 09:37 |
CowGirl...
make, model, year, engine type (diesel / mogas) automatic / manual transmissoin ????
Mountain West Diesel |
MountainWestDiesel
95 posts |
Posted:2/28/2013 10:15 |
CowGirl...
Things you have likely already done:
Check tranny fluid levels.
Check for tranny leaks.
Information I Need:
How many miles?
Do you tow on a regular basis?
What is the approximate weight of yoru tow?
Initially, sounds like your clutch plates are worn, or, you could have solenoid troubles, which was a problem in 2001 trannys.
Take it to a Dealership, or to your trusted mechanic, and have him plug in a diagnostic tool, and read the codes.
sandara
Orlando, FL, USA |
Registered on 11/18/2014 |
4 posts |
Posted:11/30/2014 23:40 |
This is the V450D01 V2, upgraded from 3-Axis Gyro to 6-Axis Gyro, and came with a new Swashplate. We were stunt by the stability and the performance of this super bird! In Walkera's flybarless series, this V450D01 V2 is the big brother of the family.
rctophobby |
