paddlrrae
Owen Sound, XX, Canada |
Registered on 10/3/2013 |
3 posts |
Posted:10/3/2013 18:11 |
The engine in my 2006 Grand Marquis misses in snowy weather; otherwise it runs smooth. Any idea why? Thanks |
Lafayette, LA, USA |
Registered on 1/5/2009 |
525 posts |
Posted:10/3/2013 19:35 |
Look for moisture / water collecting in the spark plug valleys under the COPS
curemode2002
Lehi, UT, USA |
Registered on 3/8/2012 |
147 posts |
Posted:10/4/2013 07:36 |
Also if you are actually throwing codes you can pull them to find out which cylinder is misfiring. In my case last winter I had the same thing happen found out it was number 1 misfiring, looked in the spark plug well and there was no water or anything. Moved the number 1 coil to number 2 cylinder and threw a code a few days later on number 2. After replacing the coil I was able to find a crack in the body that was allowing moisture in and causing my issues. |
paddlrrae
3 posts |
Posted:10/4/2013 08:08 |
Miss is very intermittent and brief; never throws out a code. On one occasion it did cause the radio to reset! |
curemode2002
Lehi, UT, USA |
147 posts |
Posted:10/4/2013 08:42 |
Sorry that sucks it always makes it harder to find out which one it is. I would do what jd suggests and see if you have any moisture in the wells. When you do the checks examine the coils closely for any cracks you can also check for resistance with a multimeter on the coils for any shorts.
For primary resistance, measure across both terminals (the ones that plug into the connector in the main harness). Resistance should be within .3-1.0 OHM.
For secondary resistance, measure between one of the terminals at the coil connector and the spring at the bottom (near the spark plug). Resistance should be within 3.5k-9.5k OHMs. |
