roger330
phila, PA, USA |
Registered on 10/10/2013 |
9 posts |
Posted:10/12/2013 12:44 |
hello I'm new to owning a 2000 crown Vic and when I got the car I noticed the first night of owning the car my parking lights don't work and my dash lights don't work also. but I have NO problems with the headlights working and the lights on the radio when I turn the headlight switch on.I checked all the fuses under the hood and under the dash and also opened the LCM and didn't see anything that loooked bad. can someone chime in and give me some ideas on what else to check |
Lafayette, LA, USA |
Registered on 1/5/2009 |
525 posts |
Posted:10/12/2013 16:28 |
Check to see of the bulbs are good by replacing one with a new bulb. If the new bulb works, then you had a bad bulb. If it doesn't work, you need to start checking for an electrical short, break, ir a bad LCM.
roger330
phila, PA, USA |
9 posts |
Posted:10/12/2013 23:03 |
I know its more than just bulbs but I checked them anyway because my dash lights dont come on or climate control lights and the window switchs dont light up. But one thing I will say is my radio lights dim when I turn the light switch on like it is supposed to.also when I looked at the LCM module I dont see any thing looking burned out.
1) so there is no other module that will control the parking lights ?
2) also the LCM does control the parking light correct? ???
3) would you have a wire diagram for the back lights to where ever the wires run to???? |
