Forums > SuperMotors Community Discussion > General Automotive Discussion
Polaris hs new golf remote matching method of The Key Pro M8
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 1344
dianahhh
• new york, KY, USA
• Registered on 11/18/2013
• 9 posts
Posted:12/9/2013 23:11
As for the car keys lost this issue in our lives is very common, lost the key is not what a very serious matter , as long as take the money matched with a key on it.You can refer to this website:http://www.thekeyprom8.com/.
1, through the key within 5 seconds so that the ignition switch ON / OFF three times each , stay in the off state .
2, when the turn signals flash it, prompted to enter initialization state , and start timing .
3, press and hold the remote control key latch key , then immediately press the remote control key unlock button , then turn lights flashed into the school indicating success .
4, Repeat step 3 , you can initialize additional remote control key , you can initialize a total of four remote control key .
Must Note :
1 whole learning process ( 3.4 ) must be completed within 15 seconds , automatically exit the initial state after 15 seconds.
2 after turning the ignition switch or initialize four remote keyless entry, also automatically exit the initialization state.
Remote auto key programmer matching process methods:
1 Select 5051 , enter the 17 meter , 11 landing, enter the login password XXXXX.
2 Go 10 matches into 21 channels , enter the key number , click OK.
3 all the keys, and then click Insert key to the door , switch once ( after the open , the lights are not flashing meter theft , closed )
4 key match success.
lesese
• Zibo, AZ, Sweden
• Registered on 3/16/2014
Posted:3/17/2014 00:01
Because UAVs are not burdened with the physiological limitations of human pilots, they can be designed for maximized on-station times. The maximum flight duration of unmanned aerial vehicles varies widely. Internal combustion engine aircraft endurance depends strongly on the percentage of fuel burned as a fraction of total weight (the Breguet endurance equation) and so is largely independent of aircraft size Belt CP V2 450 .
dani11
• aceh, MO, Uruguay
• Registered on 9/11/2014
• 10 posts
Posted:9/12/2014 21:00
Unmanned aircraft, typically using what kind of fuel?
Indonesia Apple Store | Jual Gudang Di Sidoarjo
